William Connors
William W. Connors
I'm working on a PC and just received my activation key for Ultraforge. I have stripped off the Beta, installed the new software, and attempted to start it. I entered the key and had activation confirmed. When the program starts to boot, I get a momentary flash of what I assume is the opening interface, and then my whole system hits a blue screen crash. I have uninstalled and reinstalled to see if that helps, but no luck. Are there known conflicts or other issues that could be causing this?
I would send an image of the blue screen, but it flashes by too quickly.
I'm not a tech guy, so any help you can provide would be great.
Zenith Beast
i know the blue screen crash error is @William Connors
Stopcode: SYSTEM_Thread_EXCEPTION_NOT_HANDLED
Cause of error: igdkmdn64.sys
William Connors
William W. Connors
Thanks! Hopefully someone will be able to use that to resolve this problem.
A new build has been published today - please redownload and reinstall UF from the download page:
https://filterforge.com/ultraforge/download.html
William Connors
William W. Connors
That did the trick. Thank you.
