linvanchene
What is the suggested way to add weights to prompts in Ultraforge?
Weights are used to either increase or reduce emphasis on a word or phrase.
Different Stable Diffusion applications seem to use different methods to achieve the same effect.
Examples found on the web:
numbers
penguin holding (a beer)1.1
photo:1.1
Numbers between 1 and 2 for positve emphasis.
Numbers between 0 and 0.9 for negative emphasis.
penguin holding a beer+
penguin holding a (beer)++
penguin (holding a beer)---
The more + or minus the larger the effect.
(parentheses) and [brackets]
(((photo)))
[[[painting]]]
() is more emphasis
[] is less emphasis
While experimenting none of these seemed to have an observable effect on the rendered result in Ultraforge.
Questions:
1) Which of these methods are we supposed to use in Ultraforge?
2) When using prompt concatenation are we required to add another node to indicate the weight of the prompt?
Unfortunately prompt weights are not available at the moment. The next version will feature LoRa support, and you'll be able to indicate weights for LoRas.
