GuyLau
Posts: 3 |
Ultraforge 1.0 Beta Testing (Works without problems on my workstation)
Windows 11 Pro - 128GB RAM - Gigabyte GeForce RTX 3070 Ti-OC-Vision 8GB Checkpoints: SD 1.5 *.safetensor (https://civitai.com/models) Hello, Are there plans to integrate support for SDXL & LoRA ? (Higher resolution and better results). This in relation to the acquisition of an RTX 3090 (24GB) card. https://www.filterforge.com/forum/read...&TID=17000 [Valhalla] Thank you for your information. "Simplicity is the ultimate sophistication" - Leonardo da Vinci |
| Posted: December 16, 2023 1:17 pm | ||
Valhalla
Posts: 50 |
IIRC they talked about this in the pinned UF thread and I'm pretty sure they are working on it, but they are in the very early stage. I'm guessing UFs release will be SD 2.1 and XL will eventually be added. Even when it's added you'll still be able to use SD 2.1 and SDXL with a LORA without the refiner with a 12GB GPU.
Right now I'm so hyped about SDXL Turbo and can't wait for it to be added to UF. It's so fast that it makes animation possible with a single 3090. It freaking generates images almost as fast as you can type! FF12 Environment Library By Valhalla - Go From ~10ish Built-in FFENVs To 327 FFENVs! mediafire.com/folder/5mof7pqxvs0fr/FFENV
Current Rig: AMD TR 3970X 32C|64T 4.5GHz CPU - Nvidia 24GB RTX 3090 GPU -128GB Ram And Two 4TB M.2s. |
| Posted: December 17, 2023 4:28 am | ||
