nekoyoubi
nekoyoubi
Per request, here is a new thread regarding bugs/issues related to the initial Ultraforge beta release. Please feel free to add/echo any findings as you can.
- no obvious logging of exceptions could be found
- shuts down within 3 seconds of starting
- crash on 2nd image generation regardless of text used
- crashes more likely with longer prompts, specifically when adding "seamless repeat pattern"
- only able to render the default image
- potential workarounds for subsequent generation crashing:
-- saving project as '.ufo' file before every generation helped me
-- someone else mentioned deselecting nodes before generation helped them, but I have yet to test this
ALZHEM
Filters: 11
I have 2 computers, in one (Windows 11, AMD, 32GB RAM, RTX3080) it crashes right away. I submitted the bug report. On my second computer (Windows 11, i9, 64GB RAM, RTX 4090) caused a BSOD.
cadranni
Author
So far, awful. I've been using Bing AI Image Generator while I waited, with a detailed prompt. Some weird details - but overall beautiful images, very usable if you have to run it a few times to get what you want.
UF crashes almost every time. Sometimes on the 1st attempt after starting the program. Tried putting in just one person - girl in black leather armor. Looks like a bad Daz3D person from 10 years ago. Head cut off, no details, not usable for anything.
Running 10th Gen Core i7 w/64 GB RAM, software installed on an M.2 drive, RTX 3090, Win 10. smile:(
Grimmy
Mr
Terrible. The first prompt I tried was an awful mess. It rendered some shapes that were complete nonsense and nothing to do with what I asked for. The second attempt it crashed.
-It crashes to desktop on every second attempt
-Render times are slow
-The only thing that renders correctly is the default kitty with the same seed. Everything else is trash.
-When comparing this to Microsoft Bing's AI image generator this is complete trash. (Bing generates 4 images in the same render time that are actually useable)
-How can I get a refund?
Here is an image from my prompt..
'4 intergalactic treasure hunters on an alien planet in a pixel art style'
Are you serious?
Ricco Biggo
Hello,
I am new to this forum but have been using Filter Forge since version 9; I came here to find more guides about how to use Ultraforge. I downloaded the Beta today.
It works perfectly for me, but I have not used other AI tools. I have Ryzen 5900X, 64GB RAM, and RTX 4070 Ti on Windows 11 Pro 22H2.
I created an image using the prompt: hippo sitting in a chair playing a guitar, wood fireplace, dark lighting, super detailed
I hope the attachment button works below... first post and all smile:D
The seed was quite high, but even low seeds result in funny results.
To the developer, thank you for creating this software and I hope I can learn more about how to use it soon.
ALZHEM
Filters: 11
Hey there, is there a way to get notified when a new version is released? (I can imagine builds will be released frequently while in beta).
Right now it's pretty bad (like I can't even run it), but knowing the team I do have high hopes about the future of UltraForge, and it's SUPER INTGERESTING that we will be able to use different models to achieve different results. Can't wait to test it properly!
STEPH08
Requirements check passed, but I can't render anything!!! (win11, i9, rtx3080Ti)
The output image with the default 'kitten' is just a square with 'concrete texture'.
If I change the texts, the result is another variation of the concrete textured square.
If I set the STEPS value to 1, I have the expected multicolored square.
If I change the value to 30, I have the concrete textured square, the rendering time is much longer, but the 'render strip' is always stuck at 5%.
Installation, I changed the default drive C: to D: but I see that the main files (about 2GB) are still on C: under Users/Public/Documents. You should let the users decide where to put the main files!
For testing purposes I reinstalled everything on C: but the results are the same, no expected output image.
ALZHEM
Filters: 11
OK, correction, my UF was crashing on my first computer because Windows Security was blocking the access to %userprofile%\Documents\Ultraforge\Cache.
Now it runs! smile:D I got my cat up and running smile:D
STEPH08
Hello,
Can you share a screenshot of your nodes for testing purposes?
Thanks
STEPH08
Interesting, I need to check
ALZHEM
Filters: 11
That happens if you have the Ransomware Protection on (I do), so a new program can't access important folders inside userprofile, program files, etc.
There is a crash reporting form, similar to the one we have in Filter Forge, but, ironically, it's currently bugged. This is our highest-priority bug right now.
Also, the exceptions are written to the log file, %temp%\Ultraforge.log -- see the attached pic below:
Drop a line to https://filterforge.com/contact/ -- they'll issue a refund, no questions asked. Include your order details into the request.
Ultraforge's generative AI nodes are based on Stable Diffusion, which is not very good out of the box. It requires some tweaking to get good results, and you can download and plug external checkpoints which are much better.
Here's a good Stable Diffusion prompting guide which shows that even the base SD 1.5 model can produce good results: https://stable-diffusion-art.com/prompt-guide/
And if you want even better results, grab a checkpoint file (.safetensors) at https://civitai.com/models, and put it into your Ultraforge vault folder (C:\Ultraforge\SD 1.5 Extras\Checkpoints). The pic below shows how to search for checkpoints that are compatible with SD 1.5:
The numeric value of the seed doesn't matter, it can be anything. A seed is like an identifier for an image -- you simply get different variations of the generated image when you change the seed.
Thank you for the kind words and your patience -- in the current state, the beta is nothing to be thankful for. We're fixing that.
You already can use custom models -- see my post above for a quick guide.
ALZHEM
Filters: 11
I saw! That's amazing, thanks! Are you planning to add support for SDXL soon?
Absolutely -- as soon as we fix the bugs, that is. SDXL will exist side by side with SD 1.5. Also, we plan to support LoRAs (and possibly LyCORISes) for SD 1.5 -- there are many fantastic LoRAs available, and we want them to be usable in UF.
And there's the ultimate Holy Grail, ControlNet, but that will take a while.
Fusionhorn
Grimmy wrote:
Here is an image from my prompt.. '4 intergalactic treasure hunters on an alien planet in a pixel art style'
Are you serious?
smile:))) I was also shocked by this new product too.
Ultraforge is an expensive poorly working shell for SD checkpoints(which also weigh many gigabytes).
This is your prompt in a completely free Fusionbrain AI service. Createn in 2 seconds.
ALZHEM
Filters: 11
Absolutely -- as soon as we fix the bugs, that is. SDXL will exist side by side with SD 1.5. Also, we plan to support LoRAs (and possibly LyCORISes) for SD 1.5 -- there are many fantastic LoRAs available, so we want them to be usable in UF.
CAN'T WAIT!!!
A last thing before I go to bed, are you also planning on adding the PNG metadata workflow that ComfyUI has? I love that a PNG can hold the nodes of how it was created.
Thanks for all the answers!
No such plans yet, but our type system should allow that.
STEPH08
fixed !! I have a hybrid system, for unknown reasons the app was not using the graphics acceleration of the Nvidia card. I manually changed the nvdia setting for the app from Auto Selection to High Performance.
Ricco Biggo
Hello Steph08, I attached the image below. Note that I was using the Tutorial as a basis to start, so it says "meal" for output smile:) I don't understand that yet since I can rename the file when I export the image. I guess it saves some keystrokes.
Also it takes about an average of about 1-2 seconds to render images if that is helpful.
15 unregistered users.
