emme
By the sound of it, the result node (type) will be a general node outputting some data - is this the case, and will we be able to load a .ufo inside another .ufo?
This should be possible, in a sense. This feature won't make it into the first release, but generally you should be able to import a .ufo file as a custom a function and use it as a node. There is a complication though: a .ufo file can have multiple Result nodes, while a function can only return a single value -- but I have some ideas on how to resolve that (e.g. by packaging all these Results into a single tuple (i.e. a package containing multiple values).
emme
I see, thanks for the info. I think that would be like the ultimate modular solution smile:D Sounds like the tuple solution might work, but in case it won't - will there be a library for custom functions?
We would love to have that, but at the moment we haven't thoght about the details yet.
