ChaosDrop
Will there be a model library for UF or will we be stuck with a single default or even worse forced to source our own?
I've played with Stable Diffusion quite a lot and having to comb the internet and security test the models is one of the most stressful aspects of the system. There's also the fact that the best models are already going pay to use.
The default SD model, at least in its current iteration, is borderline useless, so yes, we will support external models and LoRAs / LyCORISes. You will be able to plug external SD models / LoRAs into UF.
As for the library, it's an open question. Ideally, we would host some popular SD models on our servers, already converted to FF-compatible format (onnx) and accessible via some kind of package manager / dependency manager. However, this is still an open problem. I think we can't just grab models off civit.ai or HuggingFace without consent of their authors, so we'll have to discuss that with every model / LoRA author specifically.
emme
Stable Diffusion XL 1.0 (SDXL) will be releasing soon, any thoughts on including the new model in Ultraforge?
It'll be a 1024x1024 model with 3.5B parameter base model, and a 6.6B parameter secondary model. Should run on RTX 20xx with 8GB of VRAM.
I suspect the default SDXL model could be quite a bit more useful even without additional fine tuned models.
We'd love to include that, though we haven't done the technical experiments yet.
Also, we'll need to wait for the final licensing terms. IIRC, the current research license doesn't permit incorporating the model into for-profit products.
11 unregistered users.
