It just so happens that we’re working on a code library for handling cubic 2D Bezier splines in a way similar to that of Corel Draw / Illustrator (creation from list of points, appending segments, creating approximated circles / ellipses, boolean ops, outlining etc.)
The biggest problem with its integration is not the Bezier math itself, as it is well-known and well-tested. The problem is coming up with a high-level node-based language for generating static (non-animated) visual 2D content based on bezier splines that fits into FF’s node-based paradigm.
Let’s discuss this.
P.S. This is NOT a feature announcement. This code is NOT being developed for inclusion into Filter Forge. It is being developed for our next (unannounced) long-term project. However, it may be a good idea to test it on Filter Forge first, if we manage to squeeze it into FF’s architecture.
Here’s a list of things about inclusion of Bezier splines into FF that seem obvious to me. All these things can be implemented in Filter Forge without much problems:
1. We’ll need a separate type of components and inputs for Bezier splines (with pink as the official component color?). See an example pic below.
2. We’ll need a lot of spline-to-spline components. Here’s my current list: Creation: Circle / Ellipse, Elliptic Arc, Line, Rectangle, Polygon. Modification: Outline, Affine Transform, Perspective Transform, Boolean Ops, Tesselate. Editing: Append Segment, Append Linear Segment, Append Arc, Insert Point, Break At Point, Close, Merge.
3. A spline is just a spline, it’s a data structure, not a drawable object yet. Therefore, we’ll need components that ‘draw’ splines, that is, convert spline connection type to map/green. Examples may include simple fill, or a distance transform where a Map component outputs distance to the nearest point on a spline (see the pic below).
4. (Some more notes on the Distance Transform component: it’s a Map component (with a Spline input) that outputs distance to the closest point of the nearest shape, perhaps even according to customizable distance functions / metrics, such as Manhattan etc. The distance could be returned by the component as a HDR grayscale value, with positive channel values for points inside closed shapes and negative values for points outside closed shapes. The main benefit of this distance-returning component would be the ability to create perfect, non-pixelated outlines and bevels that play nice with Filter Forge surface rendering and HDRI lighting.)
5. Unlike map components which are defined implicitly, by a function, splines are are represented explicitly by a list of points, not by a function that returns values when called. Which means that spline components should (must?) be evaluated at prepare-time (as opposed to sample-time) -- that is, all spline components must be evaluated (and must have their results explicitly stored in memory) before sampling begins. This means that spline components cannot have map / green inputs, which, in turn, means that they cannot participate in sample-time green Loops. On the other hand, we can implement a Spline-typed Loop (Sigh. I wish Filter Forge had proper Haskell-like polymorphism so that we didn’t need to duplicate the Loop functionality for every new type that comes across.)
6. Since splines are defined explicitly, not implicitly, we can’t have endless fields of splines similarly to what we have with, say, noise functions. Therefore, splines in FF will resemble its Free Ellipse / Free Polygon components where we have a single non-repeating shape floating in the middle of an endless black cosmos. Which, in turn, may mean that using splines in a filter will disable seamless tiling.
And here’s a list of not-so-obvious things. I’m currently undecided about these:
1. Do we need a separate Point type to aid with the construction of splines? Or perhaps a PointList type where a single point could be represented as a degenerate case, i.e. a single-element list?
2. What other supporting machinery would we need? First-class numeric components? Numeric and point loops? Anything else? If Filter Forge was full-blown visual functional Turing-complete programming language with proper types, data structures and control structures, this wouldn’t be a problem, but alas it isn’t.
3. Do we need additional control components, for example XY Point?
4. How do we deal with importing and embedding of popular vector art formats inside FF filters? One of the problems with this is that vector art files usually contain multiple splines with additional color / transparency / fill / z-order information, while in FF splines are processed just as splines without color / fill / order etc. So, when you import, say, a SVG file into FF, you would get a collection of colorless orderless splines.
So, how would YOU integrate Bezier splines into Filter Forge, considering my points above?
What operations / functionality would be necessary for you and what would be nice to have? Will my list of Obvious Things list be enough for you? What supporting machinery would be necessary (I mean numeric math, loops / iterations, point type etc.)? How would you deal with seamless tiling? How would you deal with import / export of splines? What kinds of stuff would you do with bezier splines?
Let me know your ideas!
Here's how it may look:
Question regarding Explicit Vs. Implicit Control:
What will be the extent of explicit control over splines? Is there a point in the filter tree where we go from explicit control to implicit control of splines, or will the whole vector sub-tree be explicitly controllable?
In your example image, the user explicitly defines points, but once the initial spline data structure has been created in the Ellipse and Rectangle components, it is then modified implicitly via the Boolean and Outline components.
Let's say I like the result of the Outline component, but I'd like to modify some point positions and spline tangents. Will those kind of explicit edits be possible anywhere in the vector sub-tree?
Furthermore, if I changed the Boolean operation from Union to Intersection, any explicit edits after Boolean would be invalid, since my data set of incoming spline points will have completely changed. This sort of violates the principle of procedurality that permeates FF, and begs the question: How far should explicit control really go?
Seamless Tiling
To me, seamless tiling capability of spline shapes appears to be a must-have feature. Components of the spline-drawing type could have a Seamless Output option that would force them to output an infinite field of copies.
IMHO, a spline shape should be usable as either a non-seamless entity (i.e. for Bomber input) or as an infinite field of copied shapes.
uhm... could we define some of these terms, please?
Explicit Control vs. Proceduralism
If we stick to FF's established logic of proceduralism, it would follow that the user should have the ability to explicitly define an initial spline shape, but all subsequent operations on the initial data-set would modify it in a strictly procedural way. (This appears to be the concept exemplified in the image you posted.)
However, reading through your posts again, there appear to be some inconsistencies:
1. Your list of 'Creation' components lacks a Bezier Spline component. I was under the impression that there would at least be a bezier curve/shape editor (similar to the Curve Control editor) that would allow us to draw custom curves/shapes on a 2d plane. The way the list reads currently, one gets the impression that you planned to provide a set of primitive shapes only.
2. Your list of 'Editing' components contains some components (i.e. Append Segment, Append Linear Segment, Append Arc, Insert Point, Break At Point) that appear to break with the concept of proceduralism. If we're allowing explicit (destructive?) editing at any point in the stream, why not just have a single editor node that provides all that functionality?
This begs the question: Will there be full explicit control available anywhere in the vector sub-tree (allowing for some ad-hoc breaking of proceduralism), or do we follow the traditional FF model of strict proceduralism?
This would definitely be nice, even if vector components never make it into FF. What's the current status of 'multiple-output components'? smile;)
Cool stuff - when is it released? smile:D
Joke aside, all these makes perfectly sense to me - I don't see a problem in introducing other non-procedural flavors (the bitmap based components only "pretends" anyway smile;-) ) as long as methods exist for changing context. In fact I've long been wanting other ways to deal with placements - I use the color picker in a rather unusual way to achieve spatial control in my fractal explorer - so I welcome other more user friendly approaches.
Green <-> Orange <-> Gray converters should definitely be doable (going fr om surface to point would simply require the user to pick a rasterization point, i.e. where that one single sample is taken from).
Green -> Purple is tougher: samples should be fetches at the different point positions I guess.
I would expect compatible script components to be available too.
About import: a solution to the coloring problem would be to import it as a "group" wh ere you automatically set up the component network required to show the correct rendering.
I would expect a decent set of point related components (transformations, introduction of new points: sub dividers, reduction of points: simplifiers, extrude, jumble, align etc etc.. ).
xirja
Idididoll Forcabbage
Distance Transform and Splines! OMG!
These have been helpful:
http://members.shaw.ca/spvincent/plug...rvius.html
https://reference.wolfram.com/language...Knots.html
https://reference.wolfram.com/language...ights.html
https://reference.wolfram.com/language...egree.html
Adding math functions to create lists would be swell: https://www.youtube.com/watch?v=mxBUrIxwzHA
EDIT: Oh, and the ability to tween between 2 shapes: http://vvvv.org/documentation/damper-(animation)
Dilla, what you described above is best implemented via domain repetition. We can easily have an endlessly tiled field of spline shapes, but they won't be explicitly represented as splines (because this way you'd need an infinite array of points). Instead, this endless spline field will be represented as a regular map (green) component. Which means it's truly endless, but, on the other hand, you lose the ability to do spliney operations on it, e.g. outline, booleans, modifying points etc.
Ideally, yes, you should be able to directly access and modify points at any stage. Below is a raw list of operations on splines that I consider to be a reasonable toolset for procedurally creating them. I wrote this list for another project (see the new thread on it soon), so it may not be directly applicable to FF (due to its lack of Turing-completeness in its nodal language):
Creation
SplineFromPointList
Circle / Ellipse
Elliptic Arc
Line
Rectangle
NGon / Star
Spiral
Creation From Other Splines
Combine // NOT Boolean
Boolean Ops (And, Diff, Union, Xor)
Blend (from two splines and a percentage)
Modification
Outline
Affine Transform (Move, Rotate, Scale, Skew, Flip)
Tesselate
Perspective Transform?
SmoothPolygon (a-la Subdivision)
Optimize / Simplify
Editing
Append Segment ( BezierPoint, CloseFlag )
Append Arc
Insert Point (at point, at t, at distance etc )
Remove Point(s)
Delete Point(s)
Break At Point / Open
Close
Query
Is Open / Is Closed
Get Point At T
Get Closest Point
Tangent at Point (for arrows etc).
Yes. I'm afraid yes. Ideally, there should be a spline editor, and since you say that seamlessness is a must have, I'm afraid that it must support seamlessness too.
Ah, the good old topology dependence problem, as they call it in 3DS Max.
I tried to introduce the concept of point selection and operations on said selected points to combat this. 3DS Max does exactly the same: you can apply modifiers to a selected set of vertices / faces / subobjects selected by a previous modifier in the stack.
(Then I learned a bit of Houdini and it demolished my entire concept of selection, which began to seem extremely limited in comparison with Houdini's attachable key-value data.)
So I abandoned this approach and went with another one. See the examples of the new nodal language in the nearby thread on the Next Big Thing.
I'm still not sure which one is better.
Sphinx, the problem with converters to Gray is that everything Gray is evaluated on the Prepare stage, that is before the rest. For example, a Green-to-Gray converter is currently impossible because this means sampling a Green component during a Prepare phase, which must be completed before any sampling can begin.
It may be impractical within the current design, but I fail to believe it is impossible: I can create a new 1x1 image and take that value and enter into a gray input in a secondary rendering "pass" with the complete filter.
Just think about that green -> gray converter as a single sample rasterizer that need to render its sub branch before the main rendering can take place smile:-)
Sphinx, any sampling requires that the prepare step (i.e. the gray component evaluation) is complete. The solution you're proposing needs a sample evaluated at the prepare step, which means the prepare step must be complete, which would require a sample - so this is a circular dependency. Of course, it's a limitation of the current FF architecture, and if we had multiple passes, that would be definitely possible.
In the context of Filter Forge I wouldn't expect it to be nearly as intricate.
I would expect to be able to draw a spline with a Spline Input Component in similar fashion as you can currently draw a curve with the curve control component and then plug it into a Spline Draw Component to create a fill and a stroke, perhaps a gradient fill. The Spline Input Component would be accessible at the Settings level, not only at the Editor level, and you should be able to copy and paste the spline information from one filter to another.
I would expect to be able to import a spline saved in some common vector format into the Spline Input Component.
Having duplicates to existing components (ellipses, rectangles, stars etc.) in spline format would not be a vital necessity for me.
The ability to choose the boolean state of the individual subobjects within the Spline Input Component and group splines for further boolean operations would obviate a lot of the other needs.
Using Shift for constraining to vertical, horizontal and 45 degree angles would also be important.
This way just two components would cover just about all my bezier spline needs for Filter Forge. The Spline Input Component would have some internal complexity, but it wouldn't complicate the overall program needlessly.
For a whole new program, my answer would likely be very different.
Just wanted to note that this is a very important observation. A spline is just a data structure with a list of points, and it carries no information related to color, outline, Z-order etc. Therefore, we'll need a separate "draw spline" component in order to make splines visible.
I recently posted a thread about a whole new program: https://www.filterforge.com/forum/read...&TID=13390 - what would your answer be in this case?
Dilla, what you described above is best implemented via domain repetition. [...] endless spline field will be represented as a regular map (green) component
Yes, domain repetition. Exactly what I meant. A must-have to make vectors useful for texturing work, IMHO.
Ah, the good old topology dependence problem, as they call it in 3DS Max. [...] (Then I learned a bit of Houdini and it demolished my entire concept of selection, which began to seem extremely limited in comparison with Houdini's attachable key-value data.)
I started to look into Houdini years ago, but got turned off rather quickly as it appeared to be aimed at TDs exclusively. Disclaimer: I'm not a programmer. smile:)
Could you maybe summarize how Houdini achieves this independence from selections/topology? I'd be really interested to hear how they circumvented that problem.
I like that idea. Obviously, to really keep it procedural (and in the spirit of FF), you'd have to have a way to circumvent that selection/topology-problem that was mentioned.
re: Spline Drawing Components
One useful way to 'draw' a spline would be to map/repeat a tiling texture along its trajectory. This way you could make a bark texture follow a branch, make text follow a path, make stitching follow the edge of a piece of cloth, etc.
Good idea, especially if there's also a way to control the contour thickness along the spline (via a curve component for example).
I'm no expert on Houdini, but, if I remember correctly, it doesn't circumvent the problem.
I just meant that Houndini goes way beyond 3DS Max's concept of selection. In 3DS Max, selection is basically a boolean flag attached to a vertex / face / etc. (or perhaps a bounded float in the range 0...1, if you count soft selection). In Houdini, instead of these two fixed ways to mark elements, you can attach arbitrary key-value pairs to them, which means a) multiple "selections" and arbitrary information format for each such "selection".
xirja
A 1500 point fine spline FWIW:
Explain the image above.
xirja
My purpose is to show that splines can be a useful way to get the look of tens of thousands of points. Like your 'Atomic Particles' video, but with symmetric parametric equations and fewer particles perhaps. An elegant de jong attractor at significant cost savings. smile;)
nice splines de jong attractor xirja, where you have done this, or where you have taken it from?
It looks cool and with great gradients colors and lighting
xirja
That is Skybase's colored image I referenced. The image was linked from image search. Here's the link to the video: https://www.youtube.com/watch?v=Iq54fFsEW2Q
The black and white image was done with a custom Mathematica program.
15 unregistered users.
