Workin on a heavy-sampleage DOF script. Due to the nature of per-pixel scripting this is actually the opposite of how DOF works in reality, but sometimes it looks good anyway. Anyway my point is I'm trying to compile this and all it gives me is "syntax error" at the bottom where it the second-to-last line. I assume it's with all the breaks and loops that I havne't mastered in LUA yet.
function prepare()
blur = get_slider_input(ASIZE)*16
qual = get_intslider_input(QUAL)
rad = (2*math.pi)/qual
end;
function get_sample(x, y)
-- Image generation code goes here.
local r, g, b, a = get_sample_map(x, y, INPUT)
local d = get_sample_grayscale(x, y, DEPTH)
local t = get_sample_grayscale(x, y, F_THRESH)
local i, r
for i = 0, qual do
for r = 1, 4 do
local s = math.sin( rad*i )*(blur/r)*d
local c = math.cos( rad*i )*(blur/r)*d
if( get_sample_grayscale(x+s, y+c, DEPTH) < d ) then
break
end;
if( get_sample_grayscale(x+s, y+c, t) == 0 ) then
break
end;
r, g, b, a += get_sample_map(x+s, y+c, INPUT)
end;
end;
return r, g, b, a
end;
Edit: I took of the semicolons at the end of the if statements/ for loops but I get the same problem
Post the filter and I'll take a look at it smile:) (I can't determine your input setup)
I would suggest loading an image and it's respective depth map to get a clearer understanding of the previous nodes smile:)
Faux Lens Blur.ffxml
Okay I've been working on it and this one compiles but gives unexpected results, what am I not seeing?
function prepare()
rads = (2*math.pi)/qual
end;
local i, radius
for i = 0, qual do
for radius = 1, 4 do
local s = math.sin( rads*i )*(blur/radius)*d
local c = math.cos( rads*i )*(blur/radius)*d
if( get_sample_grayscale(x+c, y+s, DEPTH) < d ) then
break
end
r, g, b, a = r + get_sample_map(x+c, y+s, INPUT),g + get_sample_map(x+c, y+s, INPUT),b + get_sample_map(x+c, y+s, INPUT),a + get_sample_map(x+c, y+s, INPUT)
r, g, b, a = r/(4*qual),g/(4*qual),b/(4*qual),a /(4*qual)
end
end
return r, g, b, a
end;
The problem is in the inner loop - your "normalization" part is not correct, and the conditional exit caused discontinuities, so I removed that.
I cleaned up the script and moved various calculations to more appropriate places (i.e. out of the the inner loop smile:eek: ). I'm sure you'll see the point of it..
I don't see weird cutoff artifacts now, but the displacement could use some work.
Note that I bypassed all the threshold stuff as I don't understand its purpose smile:-D
Faux Lens Blur - Sphinx.ffxml
I've been working on it today and thank you so much for your help sphinx! I'm good with C++ and java but this lua syntax is definitely weird smile:D
Here's a sample image at maximum sampling and maximum macroness smile8)
It took 2.5 minutes
(Looks like I can fix up some things)
Here is the original :}
