I was going to continue work on a large script filter (mandelbulb renderer) in the newest filter forge release - now I get a new error I've never seen before:
Lua Critical Exception: Attempt to unpersist an external Lua function
My script used to work - was something changed recently related to loading external script files?
I tried to look up the error on Google, but it seems to be Filter Forge specific - what does it mean?
Anyone? I can't seem to make any of my script filters with external references work due to this error smile:cry:
Ok - the error is not related to the initial include call:
in Map Script script I tried:
Code
dofile("C:\\Users\\Sphinx\\test.lua");
where "test.lua" contains:
Code
function prepare()
   -- This function is called once,
   -- before the rendering begins.
   -- Use it for querying non-mapped
   -- inputs and precalculation.
end;
function get_sample(x, y)
   -- Image generation code goes here.
   local r = x
   local g = y
   local b = (x + y) / 2
   local a = 1
   return r, g, b, a
end;
This works just fine. I guess the error is related to actual script code in my external files. However the scripts used to work, so I need to know what that (new?) error message is about..
So, the above script works? Please attach the one that doesn't work.
I can't do that as the whole "application" use several lua libraries .. to much to set up for a simple test case.
I just want to know what triggers that error message in general (and what it means.. "unpersist" is not very clear to me). Then I can debug the actual problem myself...
Could you let me know the exact FF build which started to show issues? (there have been different builds of 2.009 on the website).
Now, a story about unpersisting. As you know rendering in Filter Forge is performed in separate passes. When you call prepare(), the Lua subsytem needs to save its results for future passes — for instance, if an unsafe script queries system time it should be consistent for all passes. We employ a third-party lib for that. In Lua jargon saving the result of a function is called persisting, and restoring the saved result is called unpersisting.
I understand all of the above is of little help to debug your problem, but if you could set up a test base our developers promise to look into it smile:)
Alright I located the problem - it is related to a change in global variable visibility..
The testcase is rather simple:
1. Create a new lua file, test.lua, with the following content:
Code
function prepare()
   t = 1
end;
   --t = 0.5
   return t,t,0,1
end;
2. Create a new filter and drop a new Map Script, enter:
Code
dofile("C:\\test.lua")
Or the path to where you put the test.lua file (remember "\\" as directory delimiter format, e.g. "C:\\Users\\GMM\\test.lua"
FF will now complain because global variable t is not registered properly (this used to work earlier).
Comment out t assignment in prepare and enable t assignment in get_sample - now it works.
The unpersist error is just a more complex version of this problem. I can send you a testcase for the unpersist error (I can't attach here due to file attachment restrictions), where should I send to?
Thanks for the info, we'll look into it.
Please send to info@filterforge
You should have a complete example in your inbox now smile:)
I'm still unpersisting my *** off here smile;) Any news on the issue?
The developers are still unpersisting your test case smile:) We'll try to fix this by the release of the 3.0 beta.
Just tested in FF3B1 .. bug is still there smile:-(
Should be fixed in 5.011 – please check.
25 unregistered users.
