I'm currently working on some fractal scripts which produce extreme range output (much like strange attractor fractals) which is clamped to either 0 or 1, and the real "magic" takes place in the super-sampling process: here the actual visible gray tones are produced.
My problem is that I can't do tone mapping because the mapped colors are either from the 0 or 1 area in the color gradient (because the super-sampling that produces intermediate grays is taking place post everything).
So how would you get around this problem? By writing a custom super-sampling step?
The only semi build in way I can figure out is to use a blur at very low radius and then enable anti-aliasing for bitmap based components, but AFAIK this is not a setting stored in the filter.
Perhaps we need a new result mode: Gradient Mapped Result, much like how the elevation gradient works, but the mapping is done post super-sampling.
Here is an output example, first half shows super-sampled output, second half shows direct output:
Wow! smile:eek: smile:)
earthbound
Is this script published anywhere? That output is pretty dang cool.
You refer to the prophecy of the pastry that will bring balance to the Force. And you believe it's this...donut?
Sphinxmorpher
I looked for it - I think I found it, but the filter doesn't render anymore (script error) :-/ I'll post it here if I can manage to fix it.
13 unregistered users.
