Currently it is possible to produce erroneous floating point number output with the script components. This will crash FF when passed on to other components. Perhaps you should add a mandatory 'Error' property?
Uh, crash? Erroneous script output shouldn't crash anything. Just tried division by zero, works fine (produces infinities). Could you post an example filter?
Yep. The crash is not one of those severe "I'll clear the ffxml, save it, stalk your mother and exit without notice" crashes.. looks like a simple floating point error, but its still there.
Hook up the gradient to the gradient map to produce the crash. Note that I deliberately made an invalid script.
I think perhaps you should check the script output before passing it on, and if invalid, use corresponding channel in mandatory Error property.
Script Crash.ffxml
This is very, very interesting. We'll look into it today.
Totte
Ubernerd
Filters: 107
I filed a crashreport or two yesterday on a crash on divide by zero (Mac OS X version)
Or really math.random(1,0).... (slider for high random was set to zero)
Totte, could you post your script as well?
Totte
Ubernerd
Filters: 107
Sorry, I think I've scrapped that, was when I was playing with adding random stuff to the fractals..
I tried to simply recreate it, but it wasn't that simple, but I'll post it when/if it happens again.
Sphinx, thanks for reporting. This will be fixed in the next update.
