If you are already a expert script coding creator, maybe ChatGPT can save you time to make it faster, but if you are like me that have zero LUA knowledge it can help maybe too
I have been seeing some tutorials on internet about ChatGPT and it seems that it can create scripts in any programming language that you may need
Then I have seen this confirmation that it can do it
So I thought that maybe it could be useful and interesting for making scripts in LUA to be used in filter forge
THE ANSWER IS YES, YOU CAN DO LUA SCRIPTS FOR FILTER FORGER EASILY
I have already tested it and if you write the correct prompt and you ask that it makes the required input editors they will be created
If there is an error in the script when tested in the map script of FF, you just simply tell the error to ChatGPT and it will be fixed
Although I have to say that when I said YES, I am still testing it, and I am still getting some errors and although it fixes it is still not working as I have zero Lua knowledge to fix it myself
But if you are an expert you can surely benefit from this as you already how to make it right
ABOUT MY EXPERIENCE WITH LUA
I have been trying to learn LUA but I am sorry that can't do it and so have no any experience
I really admire much and congratulate all of you that can be able to make such creative and useful scripts
Thanks very much for any possible help
16 unregistered users.
