Bobby_t
Hi there,
I'm looking to create a script (couldn't find a component?) to be able to clamp a range of values.
In below diagram, I've tried to illusrate as best I can, I'm looking to input values on Y and have that map to a value range on X.
For example at Y value of 10 the range in X is locked to 0,5 (mid grey) at top of triangle.
At a range of Y 5, mid grey the x range would be between approx. 0.25 and 0.75
At 0 on Y, the X can be anywhere from white to black, 0 to 1
Bobby_t
I may of over complicated above issue, worked out a much easy way to do it. smile:?:
I was wanting to limit the amount a shape could move, the bigger the shape would get (y value) the less it could move, offset (x)
11 unregistered users.
