andyz
Filters: 5
Hi it seems like scripts are very limited in re-usability. You can not even re-use the same script more than once in a filter without making a copy if I am correct.
It seems obvious that being able to add a lua script to the components section under a custom section would be ideal and very useful - but I think this is only on the wishlist so far
