Ilmeni
Filters: 6
Hi all! Is it possible to load a random image from a folder into a filter, either via script or via color control?
Or maybe to open a random image with the image component in a filter?
thank you for your help! smile:)
Let the children play. :-)
That is not possible. Not by script either, unless you write your own image importer.. that is a lot of work.
What you can do is to randomly pick an image from a number of predefined image inputs.
Or if you can use the commandline renderer it should be an easy thing achieve with a little powershell or similar. But that of course rules out the GUI and any interaction.
Ilmeni
Filters: 6
Thank you! smile:)
17 unregistered users.
