James
James
Filters: 46
So far I haven't tried using arrays in a script and I wanted to use one in a function, however the following code returns a error, any reason why?
Code
function prepare()
end;
function mat4({r1,r2,r3,r4})
    local matrix = {}
    matrix[1], matrix[2], matrix[3], matrix[4] = r1, r2, r3, r4
    return matrix[1], matrix[2], matrix[3], matrix[4]
end
function get_sample(x, y)
   return mat4({1.0,0.5,0.25,1})
end;
I'm using FF3, perhaps this is due to the version I am using or maybe a limitation in map scripts? or hopefully just an error in my code.
When using an array in the prepare function it seems to work though.
Code
function prepare()
   matrix = {1.0,0.5,0.25,1.0}
end;
   return matrix[1],matrix[2],matrix[3],matrix[4]
end;
_Agentslimepunk
Filters: 7
Code
function prepare()
end;
   -- Image generation code goes here.
   mat4(1.0, 0.5, 0.25, 1)
   local r = matrix[2]
   local g = matrix[3]
   local b = matrix[2] + y
   local a = 1
   return r, g, b, a
end;
function mat4(r1, r2, r3, r4)
   matrix = {r1, r2, r3, r4}
   return matrix
end;
Is this basically what you were after?
