David Roberson
Artist
Filters: 37
This was sort of a "what the hell" moment, but I discovered you can add multiple curve inputs to a Map Script. I'm not sure what I'd use it for, except to have one for noise profile and a second one for a contrast profile (though I could continue using the Minimum/Maximum parameters on the profile). It just struck me that I might want a different contrast profile fr om the noise profile. Of course, I still have not figured out what I'm doing, as far as adjusting contrast goes...
It did get me wondering how other people might exploit this, and how they'd manage the script to use it. In my current script, I modify the sample with the noise profile as the last step before I return the sample. I assume I'd have to have two last steps wh ere I modify the sample with the value of the noise profile, then modify it again with the contrast profile before returning the final sample.
I'm curious to see what happens, when I test it...
Edit: Okay, splicing in the extra curve works. Probably redundant and superfluous, but it does work. Of course, all of this was me just playing with a workaround for a mapped contrast adjustment.
16 unregistered users.
