Spiney
Spiney
Hi there, I'm new smile:)
Is there a variable I can plug to get the image x and y dimension in pixels?
Reason I ask is I want to calculate x and y derivatives on a per pixel basis without having to specify them as inputs.
emme
Hi,
In the result -component, check advanced mode and you'll be able to add image width/height components from there.
Spiney
Spiney
Thanks!
I ended up using OUTPUT_WIDTH and OUTPUT_HEIGHT as described in some other thread.
28 unregistered users.
