Leo Fernevak
Leo Fernevak
Filters: 14
This thread is dedicated to all kinds of debugging-tools which can be useful for scripting.
Recently I added a new function called [Debug Window]
to my snippet Text Window Mapscript -- v.03.
This snippet can be downloaded here:
http://www.filterforge.com/filters/11647.html
And here is more information about the [Debug Window]:
http://www.filterforge.com/forum/read...&TID=11511
To use the [Debug Window] simply edit the filter, copy the central mapscript and paste it into a filter which you wish to debug. (NOTE: Don't copy the Debug Simulation Script, it is only added to show how a debugging situation may appear)
After inserting the mapscript into your own filter, you may have to make sure that the text color is set to a readable tone, which is done from one of the mapscript controls.
Next, plug in the mapscript you want to debug into the [Text Window Mapscript], through the [Map Input], making sure the [Debug Window] checkbox is set.
At first, you will receive this message: "No debugging code found!"
This is because you need to set up a [Debug Code] in your source-script.
The pre-set [Debug Codes] are:
0.11111
0.22222
0.33333
0.44444
0.55555
0.66666
0.77777
0.88888
0.99999
When these codes are sent through the Alpha Channel from your source script, the [Debug Window] will pick them up and record the values of the Red, Green and Blue channel which were sent with them:
"Return number1, number2, number3, 0.11111"
While I have tested this mapscript on different settings, I also need feedback regarding any potential bug or problem. The scanning of the Alpha-Channel is using two main variables: 'xstep' and 'ystep'. Lower values for these will cause longer waiting-time but more accurate detection. If the [Debug Window] doesn't find the [Debug Code], either the 'xstep' or 'ystep' may have to be changed.
Example of a simulated debugging situation:
13 unregistered users.
