Borrus
Filters: 10
Reading through the documentation on this just now (I am using FF3, incidentally), I notice the intensity is computed by taking the straight average of r+g+b. I realise this seems at first like a sensible approach, but it's actually a bit odd, since the human eye is more sensitive to green than red or blue. A more accurate and common weighting is r * 0.30, g * 0.59, b * 0.11 or thereabouts.
Is this an oversight? Could we at least have a function returning this weighting (or close to it) too please?
Best Regards
Andy
A quick solid fix to your problem is to first use the regular node Desaturate (under Adjustments) and change the method there, and then plug that into your script.
12 unregistered users.
