RodGreen
Install failed to set permissions. This also occurred when I installed the FF2 trial.
Rod.
-------------System
Model Name: MacBook Pro
Model Identifier: MacBookPro6,1
Processor Name: Intel Core i7
Processor Speed: 2.66 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per core): 256 KB
L3 Cache: 4 MB
Memory: 8 GB
System Version: Mac OS X 10.6.8 (10K549)
Kernel Version: Darwin 10.8.0
Boot Volume: Macintosh HD
Boot Mode: Normal
Secure Virtual Memory: Enabled
64-bit Kernel and Extensions: No
Time since boot: 6 days 19:05
Please follow these steps:
- click the small lock icon at the bottom of this pane and enter an admin password to unlock the permissions box;
- if your user name is there in the user list, set the permissions to 'Read and write'. If your user name isn't there, click the '+' button and add the user to the list, then set the permissions to 'Read and write'.
- after you finish setting the permissions, don't forget to click the lock icon again to 'lock' the choice.
RodGreen
Yeah I know how to fix it. I thought you guys wanted bug reports. Seems like this is a pretty limiting bug?
As a first time user this would be a bad experience no?
Inrideo
I found that running the installer package on both 3 and Beta 4 will correct the permissions if you can't get the info box to refresh to set the permissions yourself.
It occurs for me under 10.8.2
108 unregistered users.
