Don't know if these were disabled due to that multi-threading error such as the cancel buttons but....In the curves section of the Gradients and noise components the dropdown menus for the "Profile" do not pull down....This is also the same for the "Bevels" dropdown menu in the patterns components.........
Unable to reproduce. Dropdown menues on noise and pattern components work perfectly here.
CFandM, are you using Windows XP? This seems to be an XP-specific issue. We've reproduced it, that's a bug point for you.
Yep you are correct sir. smile;) smile:)
I was going to test on 7 but did not have the time to do so...
71 unregistered users.
