Hello,
I have seen that using the FF 3.04 when loading a filter that is able to use the built-in images (does not generate the image in filter forge) happens the following:
1 - Load filter and shows the filter with the lifesaver preview
2 - Choose a new built-in preview image and so changes the preview to that image.
3 - Choose a new preset from the same filter and then the preview image changes again to the lifesaver, so it does NOT keep the previous built-in image you have choosen before.
4 - Choose again the built-in preview you want
5 - Choose another preset and again changes to lifesaver and have to again go to select the built-in preview image you want and so on.
I know that when you LOAD your own images all the presets and filters works over this image and does not change to any other and keeps this same image you loaded.
So please, could there be a way that the built-in preview choosen could be KEPT and used to test different presets on the same filter ?
I do not want to change the images preview of the presets, just that filter forge apply the preset to the built-in preset image choosen instead applying it always to the lifesaver by default.
Thanks very much
When he presets are saved the built-in images are also part of that preset..So you can choose an image and save it as a preset then the image choice will also be saved.... smile:)
Exactly. If you save a preset with a lifesaver, this preset will keep the lifesaver.
107 unregistered users.
