Jonathan Curiel
Under Filter Forge Help
Options --> Rendering Options --> Temporary files location
The sentence 'Allows to select the location for temporary files which Filter Forge may create during the rendering.' is missing a pronoun.
It should have a pronoun between 'Allows to', such as: you, the user, the program, etc.
Jonathan, thank you for your input. However there's no need to create 11 separate threads! I will note your comments but delete the other 10 threads.
Jonathan Curiel
Sorry about that...I did a bit of QA years ago and each instance was requested to be reported as a separate issue...I debated with myself whether or not to put this all in one thread. smile:(
106 unregistered users.
