Bionic
Invalid path were specified.
Exception is not submitted via built-in bug reporting tool.
Code
FFX command-line renderer [2011-09-08 07:16:57 W. Europe Daylight Time]
Exception caught at thread 00000A18 'Application':
<class XFW::OSCallError> ::CreateDirectoryW(path 'E:\Test FF3') failed with error code 0x00000003: The system cannot find the path specified.
<unknown file>(0) : <unknown function>()+0 at 00475967 in FFXCmdRenderer-x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0018E6AC in FFXCmdRenderer-x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:75B8B727, SS:ESP 002B:0018E5D4, EBP 0018E624, FLAGS 00200216
CONTEXT_INTEGER: EAX 0018E5D4, EBX 0018E930, ECX 00000003, EDX 00000000, ESI 0079957C, EDI 0018E664
Bionic
I'll post in same topic.. these are no biggie really but throws exceptions.
# XFW::OSCallError> ::CreateFile (CmdRenderer)
Invalid syntax were specified
ÅÄÖ characters that I have on my keyboard are handled more gently with a parsing failure.
Code
FFX command-line renderer [2011-09-08 08:22:59 W. Europe Daylight Time]
Exception caught at thread 00000968 'Application':
<class XFW::OSCallError> ::CreateFileW(file 'C:\Program Files (x86)\Filter Forge 3\Bin\DrWho?.jpg') failed with error code 0x0000007B: The filename,
directory name, or volume label syntax is incorrect.
<unknown file>(0) : <unknown function>()+0 at 005A9D3E in FFXCmdRenderer-x86.exe
<unknown file>(0) : <unknown function>()+0 at 005A791C in FFXCmdRenderer-x86.exe
<unknown file>(0) : <unknown function>()+0 at 00458FBF in FFXCmdRenderer-x86.exe
<unknown file>(0) : <unknown function>()+0 at 005AD37D in FFXCmdRenderer-x86.exe
<unknown file>(0) : <unknown function>()+0 at 005AD043 in FFXCmdRenderer-x86.exe
<unknown file>(0) : <unknown function>()+0 at 00402D14 in FFXCmdRenderer-x86.exe
CONTEXT_CONTROL: CS:EIP 0023:75B8B727, SS:ESP 002B:0018E3A0, EBP 0018E3F0, FLAGS 00200216
CONTEXT_INTEGER: EAX 0018E3A0, EBX 00000001, ECX 00000003, EDX 00000000, ESI 00791574, EDI 0018E430
41 unregistered users.
