Bionic
Testing different scenarios -> Moved *.ffxml -> Exception occured when file not found
Submitted via built-in bug reporting tool.
Code
Operating system:  x64 Edition (6.1 build 7600)
Physical memory: 8190 MB
Number of processors: 8, available: 8
Processor info: Intel® Core™ i7 CPU         920  @ 2.67GHz, ~3182 MHz
Filter Forge x86-SSE2 3.003.21817.36898 Release-SSE2, August 31, 2011 09:48 [2011-09-07 02:14:47 W. Europe Daylight Time]
[FFXLib::RenderingContext] Failed to load filter Library_282-2.
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x00009BF0 0x00BC0204) for window 015F0F18/015F0F18, control: <class Controls::Panel>@05BED0C8.
[Controls::Control] Exception occured while processing window message 0x00000202(WM_LBUTTONUP) (0x00000000 0x000A006E) for window 00BC0204/00BC0204, control: <class Controls::PushButton>@059E9BF0.
Exception caught at thread 000007B0 'Application':
<class XFW::IO::FileNotFound> File 'C:\Users\Administrator\AppData\Roaming\Filter Forge 3\System\Library\Library_282-2.ffxml' not found.
<unknown file>(0) : <unknown function>()+0 at 007A3CE0 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0071891D in Filter Forge x86-SSE2.exe
<unknown file>(0) : GetProcessAffinityMask()+44 at 7585B762 in C:\Windows\syswow64\kernel32.dll
<unknown file>(0) : <unknown function>()+0 at 00543A33 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006F9C64 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0048F9EB in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0051B0A7 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 005ABCE2 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 005A9D6C in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0058B37F in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:757FB727, SS:ESP 002B:00188304, EBP 00188354, FLAGS 00200212
CONTEXT_INTEGER: EAX 00188304, EBX 0AE54AA0, ECX 00000003, EDX 00000000, ESI 00AE69A4, EDI 00188394
38 unregistered users.
