Are you using FF 3.0 beta as your normal and MAIN option and not FF 2?
I mean, DO you use ONLY OR MAINLY FF 3.0 for all your work and you do not use anymore FF 2.0 or only slightly ?
I have seen in some posts that some people that already own Filter Forge 2, have changed from using FF 3.0 beta ocassionally and only as test, to use it as the MAIN software and do not use anymore FF 2.0, and only if FF 3.0 can´t make what they need or gives some error
Myself have been one of these, and I nearly worked 95% with FF 3.0 and 5% with FF 2.0, because I thought that FF 3.0 was better, have faster previews, more features and options, and perhaps would be faster in rendering.
FF 3.0 IS NOT FASTER THAN FF 2.0 ? (At least in rendering)
Now that I have made some tests with different filters I am very surprised that I found that it is really slower and takes more time to render on many different filter although the previews are much better and faster but the rendering IS NOT.
32 BIT VS 64 BIT ?
Perhaps the speed performance difference is because FF 3.0 is 32 bit and FF 2.0 is 64 bit, AND/OR because is still a beta and is not a full official version.
all of my new filter creation is now done in FF3, but almost all of my filter applications are done in FF2.
Rod_D
have you seen my eraser?
Filters: 3
I use mainly Filter Forge 2.
Rod
84 unregistered users.
