Cronkers
Cronkers
After initially installing FF3 and running filter updates, I received the message "Initial Data Download Failed ..." (see attached screen shot) and the update failed. A later try succeeded.
Rob Petershack
i believe that just means that your machine failed to connect all the way or properly to the download/library server. it's like when you get a 404 error in your browser... i think. often, you can just hit the same site or link or the library link again and it'll be fine. in other words, it's just a little glitch that happens sometimes when browsers connect to sites.
Craig is right. Our server seems to be loaded with requests from new users.
