Totte
Hello Vlad/GMX
I just realized that my Lua script based filter I do need glasses crash FF2 if the Image x or y - size is not evenly dividable by 100. Looks like a script engine bug (or script bug, but that should not cause a crash). - I never expected the Spanish inquisition |
| Posted: June 16, 2010 4:51 am | ||
Posts: 3507 |
Can anyone confirm this? I can't reproduce it under Windows (and your description implies it's a platform-independent issue).
| Posted: June 16, 2010 6:15 am | ||
Alexey Matsinin
Posts: 13 |
Totte, please post the image size that causes the crash.
| Posted: June 16, 2010 6:20 am | ||
Totte
I Will be back in about an hour, will post it then (or an image to crash it with)
| Posted: June 16, 2010 7:19 am | ||
Totte
Back!
Process: Filter Forge [10608] Path: /Applications/Filter Forge 2/Filter Forge 2.app/Contents/MacOS/Filter Forge Identifier: com.FilterForge.FilterForge2 Version: ??? (2.0) Code Type: X86 (Native) Parent Process: launchd [716] Date/Time: 2010-06-16 14:52:51.552 +0200 OS Version: Mac OS X 10.6.4 (10F569) Report Version: 6 Interval Since Last Report: 11506 sec Crashes Since Last Report: 7 Per-App Interval Since Last Report: 408 sec Per-App Crashes Since Last Report: 2 Anonymous UUID: 44852BF6-E028-4018-8D9B-1A27F021B634 Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Crashed Thread: 18 Application Specific Information: abort() called With the attached picture. P.S. That is Viggo, not Lassie. - I never expected the Spanish inquisition |
| Posted: June 16, 2010 7:54 am | ||
Igor Lorents
Posts: 39 |
It seems this crash is caused by the libJpeg library which provides support of jpeg file format in Filter Forge.
Thank you for reporting, Totte. |
| Posted: June 17, 2010 10:09 am | ||
Totte
You are welcome Igor, that is what betas are for
| Posted: June 17, 2010 10:32 am | ||
26 unregistered users.
