ronviers
lighter/generalist
For the purposes of this question I have made them easy to see by refracting them. Anyone know how to get rid of them?
Unwanted bits.ffxml
@ronviers
ronviers
lighter/generalist
This doesn't make it any better but it rules out the flip nodes.
NotFlip.ffxml
@ronviers
I think its due to rounding or precision errors somehow. If you change the input range slightly the errors are not visible. I.e. instead of a gradient span of 0..1 you can use 0.. 0.99999999. Changing this in one of the gradients should be enough.
I attached a modification that shows a simpler rounding scheme and the range hack.
NoPixels.ffxml
ronviers
lighter/generalist
Sphinx this is just great. smile:) Thank you very much for fixing it.
Love your solution to the diagonal problem. smile:)
@ronviers
SV Perry, 4 unregistered users.
