ronviers
Is it possible in v2 to know the lengths of the sides of the image? I would like to divide non-proportional images diagonally. If we can't know the lengths of the sides, is there another way? And I'm talking about exactly corner to corner.
I just noticed ArcTangent2 has x and y. If I was smart I could probably pull it out of there. Edit: Nevermind ![]() CornerToCorner.ffxml @ronviers |
| Posted: May 30, 2010 11:38 pm | ||
Administrator |
Yes, it's possible -- use Free Gradient with XY Anchor set to "Image Bounds". This way, a coordinate value of 0 will correspond to the left / top side, and a value of 1 to the right / bottom side.
Here's more info on XY Anchor: http://www.filterforge.com/forum/read...ssage82923 |
| Posted: June 2, 2010 8:08 am | ||
Administrator |
Oops, didn't notice your edit. Here's a shorter version that takes just two components:
Simple Corner-To-Corner.ffxml |
| Posted: June 2, 2010 8:15 am | ||
ronviers
Good try Vlad, but that does not work with non proportional images. Here is another way that Sphinx found but it requires four components too.
ShpinxCornerToCorner.ffxml @ronviers |
| Posted: June 2, 2010 1:02 pm | ||
15 unregistered users.
