Totte
Ubernerd
Filters: 107
Hello Vlad,
I found this while tracking down a strange problem with a filter I'm working on.
If I set a color in the ColorPicker to this (black, 100% transparency, Saturation max.
Totte
Ubernerd
Filters: 107
When opening the filter again, it is ( black, 100% transparency saturation min).
It wasn't the problem I was tracking down (which was that some drop shadows ended up gray instead of black as the transparency flowed to white, but it is still annoying smile;-)
This behavior is by design smile:)
The color information is stored as RGB internally. The RGB and HSB color models are not always interchangeable: if your color is 100% black (R:0, G:0, B:0) it can correspond to any hue and any saturation with zero brightness.
Totte
Ubernerd
Filters: 107
OK!
I just saw it as I described, never reflected over it, but the interesting thing is:
This was detected for Polygons, but for Blend, it do stick to 100 saturation, so there is still "inconsistent" smile;-)
63 unregistered users.
