Suzanne
I got the following report, and forwarded to Apple. I don't know if this will be helpful or not, but it is the same problem I had with the original beta, and which was the reason I didn't use it.
This is the part of the report regarding Filter Forge:
Filter Forge 2 universal.plugin/Contents/MacOS/Filter Forge 2 universal
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
Can someone help me get the plugin working? smile:cry:
Signed: Crybaby smile;)
Suzanne
PS: I also have FF1 on my computer.
Does it work for you in the standalone mode?
Suzanne
Initially I opened the standalone. After that I tried the PS plugin and PS crashed. I just tried to open the standalone again, unsuccessfully. I restarted the computer, opened the standalone fine. Then I closed it and opened PS. When I tried the plugin again it crashed PS. Here is the PS message that appeared:
"Could not complete your request because Photoshop does not recognize this type of file."
There is a setup file on my desktop titled documents.asp. When I click it PS opens and give the above message. It probably has nothing to do with FF2, just the document itself since the extension is .asp. At least that is my assumption.
Next I tried FF1, and it worked fine as a plugin and the standalone.
FYI-
I vaguely remember that when I installed FF1 a long time ago, I had to move everything to a different folder. I don't remember where that was now, and everything looks pretty much the same in the FF1 and FF2 folders now. It may have been the beta on FF1 that I had to move.
Suzanne
PS After the crash FF2 opened in the standalone version without my restarting the computer.
Suzanne
Thanks for the fix in new version. FF2.004 works in PS and stand alone on my Mac. No crashes. It's beautiful. smile:)
SV Perry, 43 unregistered users.
