Just wondering, since all the other 'Pattern' components do have a Repeat control. After all, one might want to use Polygon and Ellipse not only as particle shapes, but also in the fashion of Tiles, Pavements, etc., no?
[ And yes, I know Polygon and Ellipse can be 'repeated' via Bomber ].
KGtheway2B
KGtheway2B
I'd like to see this too. +1
Zoltan Erdokovy
Filters: 24
I too want to be in this club!
+1
+1
+1 for the repeat and +1 for the club.. smile:D
Totte
Ubernerd
Filters: 107
+1 For this!
Quite useful for us "tileoholics", and perhaps faster than having to go through a bomber, so we can use the bomber power to add something extra instead.
Looking at the Polygon and Ellipse components again, I noticed that there's one small problem with introducing a Repeat control:
With a minimum Repeat value of 1, the polygon/ellipse would be repeated once, meaning that there would be a 2x2 grid of Polygons/Ellipses as the absolute minimum. This would - of course - break the Polygon/Ellipse's usability as bomber particle shapes!
Consequently, in order for this to work we'd need a Repeat value of 0 as the minimum (IIRC this is currently not supported by IntSliders), which I guess is why Vlad chose NOT not give Polygon/Ellipse components a Repeat control in the first place.
Meh! Looks like we need a Repeat component or keep using Offsets instead! smile:D
Deskar
The bits for the bit workers
Filters: 30
To bit or not to bit
KGtheway2B
KGtheway2B
Or just call it "count." A value of 1 would mean 1 polygon while a value of 2 would put two polygons along the edge (total of 4).
Amethyst
Filters: 23
I've just been playing with the bomber and eclipse and the eclipse repeated in a 2x2 pattern. Anyone know why it should do this? Is it a bug?
KGtheway2B
KGtheway2B
The bomber can act as a repeater (as mentioned in the first post here). You probably have the settings mixed and are inadvertently doing this.
Posting a picture of your configuration or a ffxml file in another thread might be a better way to solve the problem if it is in-fact a bug. I think we should keep this thread on-topic though; I think a repeat control could be a valuable time-saver so I want to see it through if possible.
These two components are not finished. We just didn't have time to add all the parameters we wanted to -- actually, we just needed fodder for the Bomber, quick!
Most likely, we'll get back to these components after high-priority stuff is done.
Oh man smile:D I'm so waiting for it.
