Great new components, opens up excellent new art filters possibilities smile:) If they had green inputs they would be even better, percentage, roughness, contrast.
A new edge detection ways
Art filter foundations
A couple of suggestions:
1. Turn High Precision on for metals (and generally for anything where you're using Median or Percentile as a bump/height map). This will reduce quantization artifacts -- when High Precision is on, 65536 histogram levels are used instead of 256.
2. For art filters, you might want to turn Anti-Aliasing on. It will be slower, but the edges will be much less jaggy. Also, it looks like your example uses Maximum. I'd advise to replace it with Percentile set to 95% -- this will produce a similar look but without the ugly squares.
good stuff, carl smile:)
I like it. But I wish it didn't have a "square" bias.
here are the same examples with the High precision / Anti -Alaising .......
this is a pearl effect smile:) again a simple construction
uberzev wrote:
"square" bias
I originally thought these components could possibly be manipulated to substitute blurs, in certain situations to speed them up.
Thanks Craig but they are really just test snippets smile:blush: smile;)
Yep, that's a very desirable feature, and algorithmically it's not that complex. However, the current square-kernel version lends itself to optimizations much better, while the circular-kernel version is limited to a non-optimized brute-force approach.
Those new min/median/max components are quite nice. Here's a simple tracing filter that, besides tracing, shows how to get both min and max filtering from one min or max component only (this is possible to do with 2 pairs of grayscale sources).
Minmax Trace.ffxml
thats cool smile:)
this is another way for edge detection smile:)
med 4B edge.ffxml
14 unregistered users.
