Redcap
Redcap
Filters: 100
I am loving the new bombers; however, I would LOVE to see a feature in which I could input a single image and then have it be split up by the bombers. Kind of like a tile component, but allow random opacity, rotation, etc.
Actually, a kind of multi-slice might make a cool processing component for a lot of uses. You give it an input, a number of divisions, (x and y) and you get those outputs. If it was more than, 25, it might have to be set by remapping which one you get for each.
btw, You could build a rudimentary one yourself out of offsets and switches: it would have a fixed # though, like 2x2 or so.
Redcap
Redcap
Filters: 100
Already have, but like you suggested just give us a repeat feature like on the tiling component and presto, instant awesomeness.
P.S. Uber gave it a +1000000000000 so that means it is on the high priority list right?
No smile:)
We won't add this to bomber, that should be a separate component. From what I see, it would require multiple outputs. This is technically possible to implement, but we don't want to do in 2.0.
The reason why this should be in bomber is that bomber only allows 5 inputs. What if we want to bomb many more objects?
Use another bomber and blend the two bomber outputs?
Think about the processor Skybase... poor thing... smile;) smile:D
You can chain multiple bombers -- that is, use the output of one bomber as a Background for another. Lather, rinse, repeat.
Ooh, a background, I always used it as another particle, which is sometimes needed, but very inefficient.
Huh?
When I combine bombers, I've been setting the input bomber as a particle to the next, and not a background, so I was realizing how setting it as a background is much more efficient.
33,820 Registered Users
+14 new in 30 days!
+17 new in 30 days!
15,381 Topics
76 unregistered users.
