Zoltan Erdokovy
Filters: 24
FF2 crashes right after I click on the "try" button:
Operating system: x64 Edition (6.1 build 7600)
Physical memory: 4095 MB
Number of processors: 4, available: 4
Processor info: Intel® Core™2 Quad CPU Q6600 @ 2.40GHz, ~2387 MHz
Filter Forge x86-SSE2 2.001.14594.10210 Release-SSE2, October 15, 2009 15:35
Controls::Control Exception occured while processing window message 0x00000201(WM_LBUTTONDOWN) (0x00000001 0x007300E8) for window 000E06A8/000E06A8, control: <class Controls::SplashControl>@015B9140.
Exception caught at thread 00000CA4 'Application':
<class XFW::Exception> Unknown exception.
<unknown file>(0) : <unknown function>()+0 at 00634C90 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00729DDC in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:7515B727, SS:ESP 002B:00188B18, EBP 00188B68, FLAGS 00200216
CONTEXT_INTEGER: EAX 00188B18, EBX 063BDDBD, ECX 00000003, EDX 00000000, ESI 0097B21C, EDI 00188BA8
The interesting thing is that after installation, it run once. Then I hibernated my pc and now it always crashes.
I tried XP SP3/vista compatibility mode and run as admin, but didn't help.
EDIT: Reboot didn't help either.
Zoltan Erdokovy
Filters: 24
Hmm... if I delete/rename the Filter Forge 2 app data directory, then it runs once.
EDIT: The crash happens if either the "Search index" or the "System" directories exist.
The ZZ
Did you use installer's "Import data from prev. version" feature?
Space... it seems to go on and on forever. But then you get to the end and a gorilla starts throwing barrels at you.
Zoltan Erdokovy
Filters: 24
Yes, I did. However after reinstalling without the import option, the crash still happens.
I also tried both the plain and the SSE2 exe, no change.
Zoltan Erdokovy
Filters: 24
Same crash with beta 2.
The ZZ
Try to delete (or temporary rename) "%APPDATA%/Filter Forge 2" folder and re-run the program.
Zoltan Erdokovy
Filters: 24
Only the "Search index" and the "System" dirs need to be deleted.
The ZZ
Could you please post a full path name to your %APPDATA% foolder?
Ex. "C:\Documents and Settings\My User Name\Application Data"
The problem may be related to the UNICODEd user name...
Zoltan Erdokovy
Filters: 24
It's C:\Users\Zoltan\AppData\Roaming\Filter Forge 2 .
I removed the "read only" flag from this dir and all sub dirs, also made sure everyone has full control.
Operating system: Windows 7 pro x64 Edition (6.1 build 7600)
The ZZ
OK. Please check if there's a file named "Filter Forge x86-SSE2.log" in your %TEMP% directory? If yes, please post it here.
Zoltan Erdokovy
Filters: 24
Here you go:
Filter Forge x86-SSE2 2.002.15268.17922 Release-SSE2, December 18, 2009 13:02 [2009-12-19 18:04:35 W. Europe Standard Time]
Exception caught at thread 00004A80 'Application':
<unknown file>(0) : <unknown function>()+0 at 0064CF40 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0076303C in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00761880 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:7557B727, SS:ESP 002B:0018AE20, EBP 0018AE70, FLAGS 00200212
CONTEXT_INTEGER: EAX 0018AE20, EBX 037FD125, ECX 00000003, EDX 00000000, ESI 009B81DC, EDI 0018AEB0
The ZZ
Thanks for your report! It's much clearer now.
Could you please clear a content of your %TEMP% folder (a folder with your temporary files) and re-run the program?
I presume there's a strange file name collision that prevents FF from working in normal way.
Zoltan Erdokovy
Filters: 24
I deleted all files which weren't used by other programs, but the crash persists.
I checked other directories called "Temp", but they are all empty and not in use as
far as I can tell.
Because of other problems, I restored win7 to an earlier state: fresh install with
all drivers and apps up and running.
FForge beta was not installed in that backup, so I installed it and now I get the
30 day trial window before the crash.
One file is definitely being changed in the temp dir: the log. Once I saw three or
four .tmp files popping up for a split second just when the crash window appeared.
I wasn't able to reproduce it so it might have been some other process. Still I
checked what files I have there with the tmp extension:
~DF3D3E2BF2307603BB.TMP
HTTB65C.tmp
Both of them are used by an app and can not be deleted. Could their name interfere
with FForge?
Zoltan Erdokovy
Filters: 24
I also renamed the FForge v1 install dir, but that didn't change a thing either.
The ZZ
Please, download a new horfix: http://www.filterforge.com/download/F...0Setup.exe
It creates more detailed log which will help us to locate the problem.
Zoltan Erdokovy
Filters: 24
Uhm, isn't that the install of v1?
EDIT: I installed it but didn't change a thing: v1 runs as always, v2 crashes as always.
The ZZ
Yeah, it was actually the link to FF1.x instead of 2.x smile:D
Please download this one
install it, run, wait for a crash and post "Filter Forge x86-SSE2.log" from your %TEMP% folder here.
Zoltan Erdokovy
Filters: 24
[Controls::Control] Exception occured while processing window message 0x00000201(WM_LBUTTONDOWN) (0x00000001 0x007900EA) for window 0033093E/0033093E, control: <class Controls::SplashControl>@01500D78.
Exception caught at thread 000002C4 'Application':
<class XFW::Exception> 'Cannot create temp directory' (#1).
<unknown file>(0) : <unknown function>()+0 at 0064CE00 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0076356C in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:75D7B727, SS:ESP 002B:001880E0, EBP 00188130, FLAGS 00200212
CONTEXT_INTEGER: EAX 001880E0, EBX 046D280D, ECX 00000003, EDX 00000000, ESI 009B81DC, EDI 00188170
The log files (both sse2 and plain x86), the generated bugreport html and 3 "bitmap cache" tmp files appear in the temp directory so user permissions seem to be in order.
The ZZ
By the way, try to run the application as an administrator (via "Run As.." context menu).
Zoltan Erdokovy
Filters: 24
Already doing that, tried Vista and XP compatibility mode too.
The ZZ
What's your path for %TEMP%?
(i.e. "C:\DOCUME~1\Username\LOCALS~1\Temp")
Zoltan Erdokovy
Filters: 24
e:\temp\
Both "Temp" and "Tmp" environment variables are set to that path.
The ZZ
I'd suggest temporary solutions: a) create a new user with a "standard" %TEMP% folder location and run FF2.x as this user; or b) set FULL CONTROL permissions for your current %TEMP% folder.
Meanwhile we make a hotfix that fixes the issue.
Thank you for you patience smile;)
Zoltan Erdokovy
Filters: 24
Full control is set for everyone on %TEMP%.
Thanks for your help and happy holidays! smile:)
The ZZ
Have you already tried to create a new user with standard %TEMP% folder?
I'm sure it helps.
By the way, I'd recommend you to set permissions for TEMP to FULL ACCESS only for one user - Zoltan, and to delete any permissions for that folder for EVERYONE, etc.
UPD.
Is your %TEMP% folder a regular folder on your local hard-drive or a RAM-drive or a SUBST-dir or something like this?
Zoltan Erdokovy
Filters: 24
A new account with default settings can indeed run FForge 2.
The TEMP dir is a regular folder on an ordinary HDD. My system partition (c:) is on an SSD so I moved the temp dir to save space and IO wear.
how do you like the SSD zoltan? and how big is it?
Zoltan Erdokovy
Filters: 24
I love the combined speed of the SSD and Win 7. smile:)
I have a 32 GB version (Super Talent UltraDrive ME FTM32GX25H), so it's just enough for the system. The hibernation- and pagefile, along with all the documents and programs are all on a spinning HDD. Still, Firefox starts faster than it takes me to decide which site I want to browse. smile:)
The ZZ
I'm still thinking of buying me a new SSD of higher capacity then is installed in my netbook with Win7 smile:D
Zoltan, BTW, can you post (or send me by private message) your "set" command output?
I'm still wondering why FF2.x fails to start on your PC... I've found the procedure in our code where it happens, but I still can't understand why. It looks like your TMP (or TEMP) environment variable is set to wrong value or that folder has no enough permission.
Zoltan Erdokovy
Filters: 24
I sent you the SET command output.
The temp dir works for FForge v1 and all other apps and even FForge v2 if I delete the "System" and "Search index" before each run.
After a successful v2 run, the log says the following:
Filter Forge x86-SSE2 2.002.15320.35298 Release-SSE2, December 23, 2009 11:55 [2009-12-24 21:05:51 W. Europe Standard Time]
Search Indexer started...
~FilterSearchIndexer: Found regular file where directory expected (1)Search Indexer terminated.
Zoltan Erdokovy
Filters: 24
Bloody hell, you were right ZZ, the backslash at the end was the problem. I changed
e:\temp\
to
e:\temp
and now it works!
Thanks for the help and happy holidays ZZ (and any other Filter Forge related person). smile:)
The ZZ
It's a right time to say "LOL" smile:D
ahimsa
Filters: 41
Mine won't open at all. It opens the buy or use as demo thing, but that's it.
Ahimsa, have you tried entering the beta key?
ahimsa
Filters: 41
I haven't gotten it yet. I tried to open it as a demo, it froze, I click the buy button and it wants money.
Please contact us via the Contact form to request a beta key.
ahimsa
Filters: 41
I did that yesterday, no response yet.
SV Perry, 8 unregistered users.
