It would be useful with a simple boolean property to bypass the bitmap cache and pass through source samples in conventional procedural manner.
The reason for this is easier empirical testing of performance improvements and/or qualitative impact. Also this could be used to give the user the final decision about quality vs speed.
We plan to implement this functionality via a separate Bypass component. I'm afraid I can't give an ETA for its appearance.
Not a component, of course. We'd like to implement a proper Bypass feature, but this is not a trivial thing to do, because a proper bypass would require two internal component trees -- one visible to the user in the Editor, and another one for the renderer with all the bypassed components thrown out. This is a significant rewrite because the current Editor uses the same single tree for both the UI and the renderer.
A real infrastructural Bypass would be awesome and preferable. I understand why that is alot work smile;-)
A simple internal bypass (i.e. f(x) -> x) would also do - perhaps as a first edition before the "significant rewrite".
Anyway, I'm glad to hear you're considering the feature smile:-)
We even have a preliminary design for it:
Here's a more recent pic that looks a bit better:
Looks good smile:-)
How is it going with the work on "The Next Big Thing"? Need testers?
In short, GPUs are weird, hard to program, and we still have no idea what to do with them on Mac, especially given Apple's transition to their own silicon.
And BTW, the screens aren't from The Next Big Thingy -- they are from an Editor overhaul we're planning for normal, regular Filter Forge.
emme
So, is The Next Big Thingy currently on pause, or still in development? Too bad about the GPU difficulties, but it's understandable.
The new FF editor designs look clean. Looks like there might be some new functionality along with the new visuals? Is this planned for version 10 or for later?
No, not on pause. The current focus is a tile-based / render-on-demand architecture for GPUs, which is needed for rendering anything bitmap-based.
There'll be a lot of new functionality -- dragging connectors from inputs (not just from outputs as before), click-click-connections in addition to dragging, ability to reconnect connections coming from an output, component creation menu available during connecting (like in Houdini / Unity / Unreal), dots for rerouting connections, named pins for distributing connections, named wireless pins for laying connections through the air, ability to rename components, collapsible component previews, framed groups (like in Unity), and a proper bypass -- but this one may take a while.
Oh, and design-wise, every single thing is now aligned to the grid, which hopefully will somewhat mitigate spaghetti networks facilitated by the current editor.
That would be nice, but the development may take longer. We'll see.
This is indeed exciting news smile:-) Looking forward to that update.
emme
Awesome! This will really make the workflow more robust.
One small but useful feature would be the ability to duplicate connections fr om inputs with a modifier key (like ctrl). There's a connection from A -> B and I want to connect A -> C, I could simply ctrl + drag from the B input to C input and duplicate the connection. Useful for large trees wh ere the components can be very far from each other.
Maybe the features you listed already solve this smile:)
No, they don't smile:) This sounds like a good idea.
11 unregistered users.
