If possible please enable HDR output for the Bitmap Cache component smile:-)
Source is HDR, but output is clipped (LDR).
Also this may call for a "Clip HDR Before Averaging" checkbox in the rasterization options of the source prop
This is a bug which we're currently fixing. Of course, the Bitmap Cache component should have HDR output.
emme
Good to hear. Related, would it also be possible to make the blur component output HDR?
Ah great, I also found it rather strange with HDR input but not output. Emme, Blur is already HDR smile:-)
emme
Sphinx, Blur only outputs LDR for me... Am I missing something?
Well it worked earlier (here V9). But I can see that its broken in V10 - probably the same bug (also the Blur component has the yellow hdr sign at the output, while the Bitmap Cache has not).
This is already fixed, should be out in the next update or hotfix.
emme
Ok great smile:)
