betatester65
I try filter forge in acdsee pro 2018 as 64 bit plugin. when want open the plugin the error come. is it possible to fix, or need this do acdsse developer ?. i think acdsee send a image with alphachannel but filter forge want no alpha channel. in theory filter forge can be happy and just do nothing with alpha channel
This is somewhat expected, since Acdsee is not supported as a host application:
https://www.filterforge.com/download/hosts.html
However since you're using FF7 you don't need the plugin - simply copy and paste your image from Acdsee into FF and back.
19 unregistered users.
