angelize
angelize
Filters: 17
not sure if this is a bug or if PNG files are not going to be supported but I copied a PNG file to the clipboard (created in Xara Designer Pro) and got an error unknown bitmap format in memory stream.
I tried again and I got a png to load but it had transparent areas that were completely filled with the renered texture.
closed FF7, reopened and tried again now back to error.
Opaque PNGs should be supported, though you'll need certain luck with transparent ones.
Please attach the file here or send it to the support team if you want us to look into it.
