Updating an old filter today and adding some features I came accross this bug...I narrowed down the bug to its basic tree....Here is the fitler to produce the bug along with this video of how to re-produce the bug......
CURVE EDITOR BUG
test me.ffxml
Also to reproduce the bug just edit the curve in the settings then uncheck periodic and select the dropdown menu on "Leftward"
CFandM, most your reports are easily reproducible but this seems to be an exception. The dropdown list works fine for me.
I really don't know what I should do beyond what you demonstrated in the video. Can anyone else confirm the issue?
Ok I thought about this and had a thought about what might be different....People like different themes in windows and not all themes are alike...So I loaded a different theme and tried it....The bug did not show its face.....Its only when I used the Windows7 basic theme.....I tried other themes as well as the aero....The bug only shows up on the Windows7 basic theme..So it could be just something up with that theme itself......Here is a video of that bug with the theme changes......CURVE EDITOR BUG 2
Update.....Just out of curosity I tried this in FF6 with the Windows 7 Basic theme...I got no bug to show up and all works as it should...Only FF7 is affected
by this bug......
Thanks for the details! I can't test it myself since my Windows10 office machine only supports Aero themes - but I will ask our tester to reproduce it.
Glad to help!......Guess its a localized bug rather then a global bug... smile;) smile:)
Should be fixed in 7.006.
