I'm on the latest FF 7 beta and the command+z doesn't seem to work. I hit it and it doesn't execute undo.
Here's just what I'm using.
MacBook Pro (15-inch, Late 2016)
MacOS 10.12.5 (16F73)
It's not cmd+z that doesn't work: something seems to steal focus from the last selected item.
We have reproduced the following: when you move a component around the editing area and press cmd+z it doesn't undo. However if you click on the empty space in the editing area before pressing cmd+z, it will undo correctly.
To sum it up: it is definitely broken but an extra click is an easy workaround. That's a bug point, of course.
Should be fixed in the today's hotfix. Feel free to reinstall and check it over.
It appears to be resolved! Thank you smile:)
