OSX 10.11.6, FF 6.004 beta
Using the Surface Texture Engine as an example, do the following: 1) Edit the filter. 2) Zoom in on the Result area. 3) Choose the pointer tool and select the Brightness/Contrast 6.002 component. 4) Type Command-Z (undo). Nothing happens. 5) Select the Switch component. Type Command-Z. The "focus" is returned to the Result component. I checked other components in this filter that did not respond to the undo command when selected. They are: Brightness/Contrast 6.002 Blend Hue/Saturation Profile Gradient 6.002 Color Control Offset IntSlider control Slider control You probably need to check other components as well... Math meets art meets psychedelia. |
| Posted: November 4, 2016 5:29 pm | ||
Posts: 3507 |
Yep, looks like a bug or at least like inconsistent behavior. A bug point for you.
| Posted: November 9, 2016 5:06 am | ||
15 unregistered users.
