When I was editing a filter in FF 6.003 beta on Mac OS X 10.11.6, specifically Edit Filter Info / Description, I pasted some text (Command V) from Firefox into the Description field and it kept the Firefox font type. No problems otherwise. When returning after saving the Description the font was correct. Here is a snapshot
Rick, I fail to find the problem in your message. So, what is the issue?..
What I'm saying: when I pasted a message into the Description field the wrong font appeared. This is only a "cosmetic" issue, does not cause program problems.
I guess this is just a standard MacOS edit box. It shows what you have pasted into it. Of course the font variety is not saved in the filter description.
Ok, did not know if it was something you could prevent, obviously not a real bug.
16 unregistered users.
