This might be a cosmetic bug, or it might be... intentional?
See attached image. Preview is actually locked on the right Image component, but the context menu for the left Image component shows a tick icon next to its 'Lock Preview' option, implying that preview lock is active for this component. Obviously, this is NOT the case. ![]() --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: July 29, 2016 12:50 pm | ||
Posts: 3507 |
I'm pretty sure this is intentional. All Image components are just instances of the same entity. You will get the same behavior when you lock preview on an instanced Group.
| Posted: August 2, 2016 9:15 am | ||
My bad, I chose a poor example. Try the following instead:
1. Create two different components. 2. Lock preview on one of these components. 3. RMB-click the other component. 4. Note the existence of the tick icon left of the 'Lock Preview' option. I find it hard to believe that this is intentional. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: August 2, 2016 9:25 am | ||
A more drastic example:
1. Open any library filter with the Filter Editor. 2. Lock preview on a component of your choice. 3. Begin inspecting other components via RMB-click. 4. Note that all components you inspect will have a tick icon left of their 'Lock preview' option. Intentional? --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: August 2, 2016 9:30 am | ||
Posts: 3507 |
Believe it or not but Vladimir said this was intentional. A tick icon in the right-click popup menu is a control allowing you to reset the lock preview quickly.
| Posted: August 30, 2016 9:21 am | ||
