DanielBiggers
CGDreamer
Filter forge 6 beta in PS CS4 64bit shows message saying Cannot load one or more shortcuts - the filter file could not be found. After closing the plugin and opening it back up I did not see the error message again, so I am not sure if it just needed to open once for FF to create the folders.
This is not a bug. If you make some filters inaccessible to Filter Forge – like you delete an .ffxml file, or rename a folder with filters – Filter Forge will report that something is not found.
DanielBiggers
CGDreamer
Ok thank you. I didn't delete/move any folders but it may have been in response to having the new 64 bit option needing to create new folders with a fresh beta 6 install.
