I've been monitoring Filter Forge 6 beta on a MacBook Pro (Intel i7 processor, 4 cores, 8 threads) and have noticed that CPU usage according to the top utility run from the command line yields results that I don't completely understand.
Average CPU usage according to top:
Impressionist Curve - 160% - Bomber+ with image/arc tangent in loop for brush direction,
Impressionist Twist - 300% - Bomber+, relatively simple.
Spectral Mandelbrot 2 - 770% (not kidding) - LUA Script component filter.
These numbers are rough averages. BTW, 800% is the highest value top can return for this processor (8 threads per processor).
In general I found that most filters ran between 160% and 300% that did NOT contain a script component. What does this mean??
Do you mean that 800% would be telling that it is using all the 8 cpu threads at 100%?
i think that the bomber plus can be explained that is slower than bomber standard
Do you mean that FF 6 does not use at all the full CPU power of the processor and only uses up to a third of it?
That's odd.
On my 4-core Windows computer, according to the task manager:
All four cores are running at 100% (I guess you would call that 400% ?) while Filter Forge is rendering. I don't mean that Filter Forge is using all of my CPU, I mean that Filter Forge + everything else = using all of my CPU. In other words, Filter Forge uses all available CPU that isn't being used by something else.
This has been true since FF 1 if I remember correctly, including on my previous computer, and hasn't changed with FF 6 Beta.
Yes, Indigo Ray, 400% is four cores. SpaceRay, as for FF using most of the Mac CPU, I'm afraid not. This is a serious issue on the Mac, IMHO.
I did a quick look at FF 5 for top CPU values:
Most filters: 300-400%
Some Bomber+ filters: 150%
I'm thinking that FF does not see the extra "threads" provided by the i7 processor on the Mac. But I do not know the internals, so I'll leave this to the experts...
LexArt
LexArt
Thanks Rick Duim for making this tests of monitoring CPU on mac and that gives this bad results showing that FF 6 does not use all the cores of the CPU, which is very bad
How are you monitoring the CPU, what software are you using?
I think that if this true that does not recognize the additional cores, or is unable to use the full CPU is a very bad thing, at least on Mac
which is very bad
This is kinda typical for FilterForge and many other programs alike (for example, AE often doesn't use all cores to render stuff out even if it were advertised that it's multi-threaded). I never took this as a bad thing, let a lone don't see the reason to stigmatize it as wrong but it does raise some questions in regards to how the program handles multi-threaded renders.
It might be worth understanding it for future reference.
