rjino
New to filter forge so sorry if this has been addressed already.
The filters are only rendering 80 per cent of the image. Image size is 1920x10180 pixels. Is there size limitation on the beta.
MacbookPro 15Inch
2.6 Gig Intel Core i7
16 Megs Ram
NVIDEA GeForce GT 750
rjino
This was reported as rendering only 80% of image. However, in fact, the full image is rendered but the render does not respect the crop made in photoshop i.e. to see the full render the image has to be repositioned from the top left corner. All filters so far have this behaviour.
You’re either using a selection (the filter is applied to the selected area) or your image is larger than the canvas (the filter is applied to the visible area). Please fix that, and everything should work fine.
You can also use Filter Forge in the standalone mode.
rjino
Thanks for the reply. Yes, the image is larger than the canvas. The filter is however applied not to the visible portion of the image/canvas but to an area starting from the top-left of the pre-cropped image area. The work-around is simple but the expected behavior is that the visible area is rendered. Otherwise this is an excellent filter generator. Wish that I'd come across it before.
12 unregistered users.
