missi
I'm not even going to pretend to know what's going on with this, or if it's even a 'bug'. I've attempted to use FF 6 twice and both times it has crashed, taking Photoshop along with it.
Using FF through the filters menu in PS CC 2015, I can cycle through filters within FF, but clicking back over to PS to view the original image and clicking back over to FF crashes both programs immediately.
I don't know what any of it means, or if it is helpful, but the info generated by the bug reporting tool is attached.
ON EDIT: I don't see the attachment..here is the text:
Operating system: x64 Edition (6.2 build 9200)
Physical memory: 32655 MB
Number of processors: 8, available: 8
Processor info: , ~0 MHz
Filter Forge x64 6.001.40221.56882 Release, June 10, 2016 12:08 [7/1/2016 12:40:23 PM Central Daylight Time]
Exception caught at thread 0000000000002650 'Application':
<class XFW::OSCallError> ::WriteFile(block 4, parent pipe 0000000000003F54, slave pipe 000000000BEEF098) failed with error code 0x000000E8: The pipe is being closed.
<unknown file>(0) : <unknown function>()+0 at 0000000140527C35 in D:\Program Files\Filter Forge 6\Bin_x64\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 00000001404FB761 in D:\Program Files\Filter Forge 6\Bin_x64\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 00000001402406A9 in D:\Program Files\Filter Forge 6\Bin_x64\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 0000000140299102 in D:\Program Files\Filter Forge 6\Bin_x64\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 0000000140290E16 in D:\Program Files\Filter Forge 6\Bin_x64\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 00000001402914A2 in D:\Program Files\Filter Forge 6\Bin_x64\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 00000001402993E4 in D:\Program Files\Filter Forge 6\Bin_x64\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 0000000140861D50 in D:\Program Files\Filter Forge 6\Bin_x64\Filter Forge x64.exe
<unknown file>(0) : BaseThreadInitThunk()+26 at 000007F828CE1842 in C:\WINDOWS\system32\KERNEL32.DLL
<unknown file>(0) : RtlUserThreadStart()+33 at 000007F82934DF11 in C:\WINDOWS\SYSTEM32\ntdll.dll
CONTEXT_CONTROL: CS:RIP 0033:000007F82662AEA8, SS:RSP 002B:000000000083F540, FLAGS 0000000000000206
CONTEXT_INTEGER: RAX 000000000CF40001, RBX 0000000140D81DD0, RCX 000007F8266CF000, RDX 00000000000F4000, RBP 000000000083F680, RSI 0000000000000004, RDI 000000000083F6E8
CONTEXT_INTEGER: R8 000007F8265E00F0, R9 00000000000F4000, R10 000007F828CE3DA3, R11 000000000083F2C0, R12 07FFFFFFFFFFFFFF, R13 0000000000000000, R14 0000000000000000, R15 00000000FFFFFFFF
No, this is not a bug — the "pipe is being closed" message means Photoshop terminated the link between the host and the plugin. We can do nothing about that.
13 unregistered users.
